08-30-2025
15:35
06:33
MarioSFitbit
08-30-2025
15:35
06:33
MarioSFitbit
Sleep tracking is STILL not working properly!! Will someone from Fitbit please fix this? This function is extremely important to me and it is not working correctly. This is not the first time I’ve complained about this and I really would like a fix, a workaround, anything to solve it.
Moderator edit - updated subject for clarity
09-03-2025 03:05
09-03-2025 03:05
Good luck with that I have been on to support since 10 July regarding this and keep getting fobbed off, they know it is their issue but have you going around the houses trying different things rather than say their update has messed it up!
09-02-2025 16:26 - edited 09-02-2025 16:30
Welcome back to the community forums @julesjmj.
Thank you for sharing the inquiry about this difficulty with your Inspire 3.
Even if you already tried some of the following steps, I'd like you to confirm that you have followed these steps below:
Also, for more detailed information, see What factors can affect my heart-rate reading on my Fitbit device?
Keep in mind that you must see sleep stages in order to see your sleep score information. Please swipe left on the Sleep Score graph, here you can see information about your weekly sleep average and sleep duration. To get more detailed information, see What's sleep score in the Fitbit app?
I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
09-03-2025 03:05
09-03-2025 03:05
09-07-2025 14:00
09-07-2025 14:00
I was on Alaska cruise, my sleep data were so messed up. It shows I slept everyday afternoon 5pm till 11pm. My fitbit clock is sync-ed correct with my Wifi on and all worked but Sleep time and score. and I was home last night, got every good sleep, no sleep score!
09-08-2025 09:39
09-08-2025 09:39
I hope this gets fixed ASAP because I just bought my new Inspire 3 when my old Versa 2 drowned, and more than half of what I use it for is sleep tracking and sleep quality.
If thats screwed up, I may as well get a refund now.
09-08-2025 13:27
09-08-2025 13:27
I assume mine messed by Google took it over. Hopefully it will get better ( ps, last night was okay, not bad as few days ago)
Best Answer09-29-2025 08:29
09-29-2025 08:29
This reply from ManuFitbit is irrelevant to the issue I have raised multiple times regarding this. It is not the tracker itself. It is the app and how it handles sleep logs.
Best Answer10-04-2025 07:51
10-04-2025 07:51
Not working for me for at least a month. Records awake more that 50% of time in large blocks. Could my sensor be worn out?
Best Answer10-09-2025 08:53
10-09-2025 08:53
That’s actually very unlikely. I don’t even know how many years I’ve had my current Fitbit for, but in all the years that I’ve had Fitbits, a sensor has never worn out. If your issue is with the actual record and not with how the app is handling the logs, then it is more likely due to where on your arm the watch is sitting while you are asleep.
It should not be too loose nor too tight and should actually sit above your wrist by an inch or so. You can also adjust the level of sensitivity to movements in the settings for sleep. So if you move around a lot, your sensitivity should not be set to sensitive.
10-11-2025 15:23
10-11-2025 15:23
The sleep tracking problem isn't because "Google took it over." I've had Fitbits since the Flex (2nd one, many years ago). Google has improved Fitbit noticeably, although I cannot cite specifics, because I haven't kept track.
The sleep data problem is apparently the result of a fairly recent reprogramming of that particular function, and I've read recent (mid-October 2025) reports from others that it is now fixed. I now have a Charge 6, and it's OK most of the time, but I use the Sensitive setting.
Best Answer10-23-2025 06:32
10-23-2025 06:32
Well, in my opinion, it is. I don’t know if it’s because of Google take over but it is absolutely since Google’s take over. all that really doesn’t matter, though. What matters is the fact that it still does not work the way that it should or the way that it used to. By this, I do not mean the actual sleep tracking by the device, but rather the apps logging of it. I don’t know if that makes sense to anybody, but they are two distinct things
