10-01-2024
21:54
09:47
10-01-2024
21:54
09:47
Why just why would you people Make a fitness watch that is less compatible with i phones?????? Are you guys nuts? Or what?! Fix this!!!!
Hello @Babecutie and welcome to the Community. Can you please give more details about the problem you are having? All Fitbit models are compatible with an iPhone, as long as it uses iOS 15 or newer.
Laurie | Maryland
Hi there, @Babecutie. Welcome to the Fitbit Community Forums. We‘re taking your comments and sentiments in regards to our products into consideration.
As @LZeeW has mentioned, Fitbit devices and iPhone devices are pretty much compatible between each other. I'd recommend checking if your mobile device meets the requirements to properly operate with your Fitbit device. For more information, see Fitbit Compatible Devices.
To better assist you, please let us know the issue you're having so we can assist you.
In case you're running into syncing issues, please see Why won't my Fitbit device sync?
Best AnswerObviously they are not as many users conplain about the same issue
i have my inspire 3 since this spring
iphone 14 and syncing issues since the beginning
and now since 1 month it hardly syncs at all
i cannot see any data, change my screen on ghe watch
no i habe deconnecred it from my phone to install it from scratch but it won‘t let me anymore since the watch does not show me the 4 digits to connect
blurtooth is on an the app sees my inspire 3 but data cannot be exchanged
Best Answer@Babecutie Apple does not allow iPhone users to respond to texts on their Fitbits. There isn't anything Fitbit can do to change this because it's a business decision that Apple has made.
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
