09-15-2024
09:58
07:03
09-15-2024
09:58
07:03
Updated Inspire 3. Received message successful. After short while screen/face went blank. Tried suggested fixes. Got a screen/face for a short time, then no screen/face. Attempted fix again. No success. Inspire 3 is less than 1 year old. Very frustrated!!!
Best Answer09-16-2024 07:15 - edited 09-16-2024 07:15
Hi there, @kw24. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Inspire 3 is still not turning on. I understand how annoying this can be, I will do my best to help you with this!
I've seen you contacted our Support Team after posting here and they already offered a resolution. If you have any questions or concerns regarding the outcome of your case, please feel free to contact our team back.
Thanks in advance!
Best Answer09-17-2024 08:24
09-17-2024 08:24
Best Answer09-17-2024 08:45
09-17-2024 08:45
@MarreFitbit, is there a way to perform a Factory Reset on an Inspire 3 device without using the device screen to do it?
If there is a screen issue of any kind that prevents the user from going through the settings to perform a Factory Reset, if a simple restart doesn't resolve the problem, then the user is left with a brick that can only be returned for a replacement device.
