03-06-2024
10:17
11:25
CrisVillaFitbit
03-06-2024
10:17
11:25
CrisVillaFitbit
Hi, excited to use my new Inspire 3 in the pool today. Heartrate tracked at vigorous to moderate for most of my 1625 metre swim but says I only burned 277 calories. If I enter this manually as an exercise it gives me 466 burned which is accurate based on all the calculators out there. Any idea why the calories burned count is so low? Thanks
Moderator edit: edited title to clarity.
03-07-2024 11:29
03-07-2024 11:29
Welcome to the community forums, @Omi18.
Thanks for letting me know about this situation in regards to the calories burned tracked by your Inspire 3 while swimming.
My best recommendation would be restarting your Inspire 3 and double check you're wearing it correctly, since this can impact the data tracked by your Insprie 3.
Let me know how it goes once you've checked this out, please.
03-07-2024 11:29
03-07-2024 11:29
03-19-2024 10:48
03-19-2024 10:48
Thanks but I already had everything set properly, still do and it never calculates my swimming calories burned correctly. I will continue to enter manually
03-21-2024 05:35
03-21-2024 05:35
Welcome back, @Omi18.
Thanks for letting me know how the situation went, you can also try restarting the device and then check if it works the same way.
03-21-2024 05:42
03-21-2024 05:42
