02-08-2024 07:25
02-08-2024 07:25
Best Answer02-17-2024 01:48
02-17-2024 01:48
Hi, @dincyb, welcome to the community, have you seen How do I track my sleep with my Fitbit device? - Fitbit Help Center ? Sleep tracking is quite a complex issue, you will see that you need to be at rest for about an hour before it is tracked as "Sleep", also note there is a normal/sensitive setting. You should also be aware that tracking depends on getting a consistent HR reading, how you wear the device is important, if you have a tattoo or scar tissue where you wear your Inspire 3 this will cause problems with HR.
If you are a restless sleeper this will interrupt the process. If your problem persists I would suggest you get a family member or friend to wear your Inspire 3 for a couple of nights to see if it makes any difference.
Let us know how you get on by posting here again.
Cheers
Gr4ndp4 | UK
