07-03-2024
04:16
08:04
07-03-2024
04:16
08:04
Hi,
I've been very happy with my Inspire 3, but 6 months on it has now stopped vibrating. I have reset the device, checked it isn't in DND and that vibration is set to strong. It doesn't vibrate when placed on the charger either, so I think there is a physical issue with the device rather than software.
Has anyone else had the same problem?
Hi there, @RipleyJump. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Inspire 3 is still not vibrating. I understand your concern, I will do my best to help you with this!
As our last resort, I'd recommend performing a factory reset on your Inspire 3. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
With the above being said, please sync your Inspire 3 and then, proceed with the steps below in the order listed:
You can follow the steps to set up the device after that How do I set up my Fit-bit device?
If the issue persists after the steps above, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Thanks in advance!
