I know this question is asked often and frequently, but after trying every fix/hack suggested, it still isn't functioning properly and unfortunately Fitbit doesn't offer direct support. Any ideas on how to fix this? It's really frustrating to purchase a product that only half works.
Hi @LizMc85. Welcome to the Fitbit Community! It's great to have you here!
Let me help you with the SpO2 and sleep tracking with your Inspire 3.
Spo2 data is collected from your sleep, so if you don't get sleep data, your SpO2 may be missing too. If you received a sleep log, but it only includes your sleep pattern check the following possible causes:
For more information about why you got your sleep pattern instead of sleep stages, tap or click the sleep record that shows your sleep pattern.
I hope these suggestions will be helpful for you!
