06-27-2025
06:49
08:07
DavidFitbit
06-27-2025
06:49
08:07
DavidFitbit
In the last couple of days my alerts no longer function. Setting an alarm or timer no longer vibrates. I've restarted both my tracker and my Android phone, updated all apps on my phone. Removed and re-paired the tracker. Nothing is getting the vibration going again. Tracker is not yet 2 years old.
ETA: also verified that the silent modes are not set.
Moderator's action: Merged response
06-28-2025 12:16 - edited 06-28-2025 12:16
Hi @Safyre, thank you for posting in the community. It's great to have you here,
I'm glad to help you with the vibration of your Inspire 3. I appreciate all the troubvleshooting you have already tried.
Your device will vibrate in certain situation depending on your settings. An easy way to test the motor (the one that vibrates inside the tracker), is by setting an alarm. Since you have mentioned you already tried that, please tell me if you see something in the display when the alarm should go off.
Please also follow the instructions below to restart your device and tell me if the device vibrates according to such instructions:
Best Answer07-01-2025 05:47
07-01-2025 05:47
The tracker has not responded to any of the suggested solutions. Apparently the vibration board is dead. Less than two years old and it's now pretty useless since it's not only my tracker, but my timer and alarm system.
