07-15-2024
22:57
06:12
ManuFitbit
07-15-2024
22:57
06:12
ManuFitbit
Hi I have had my fit bit 3 Inspire for about a month. Some days it logs oxygen saturation other day not. Usually there are 5 out of 5 stats showing. Today it is 4 out of 4 with a message saying the oxygen saturation may be available in my area. What does this mean.? I haven't changed any settings do I don't understand why it has suddenly disappeared of my stats? Any ideas? I wear it snug on my wrist so that's not the issue. Thanks
Moderator edit: clarified subject.
Best Answer07-16-2024 06:10
07-16-2024 06:10
Good to see you participating in the community @KayeP.
Welcome to the community forums. Thank your for taking the time to share the experience that you are having with Inspire 3. Sorry to know the inconveniences.
Please keep in mind the following to make sure you see your health metrics data:
For more detailed information, see What should I know about health metrics in the Fitbit app?
Regarding SpO2, keep the following in mind to make sure your Fitbit device successfully measures your SpO2 values:
Turning off any clock face permissions can cause the clock face to stop functioning. To check these settings:
Your Fitbit device must be able to consistently track your SpO2 data:
Wear your device slightly higher on your wrist.
Make sure your device is in contact with your skin.
Your device should be snug but not constricting.
Tattooed skin can impact the accuracy of the red and infrared sensors on your Fitbit device.
08-13-2024 13:32
08-13-2024 13:32
This same exact thing happened to me!!! And i have been reading the forums and realising that this is happening to most users of Inspire 3! I have already gone through every single step mentioned below by @ManuFitbit and nothing works. @Fitbit where is our SpO2?
Best Answer08-14-2024 10:07
08-14-2024 10:07
Can’t seem to setup the Sp02 clock face. Can you advise how? Following directions, but not complete
Best Answer08-14-2024 18:44
08-14-2024 18:44
Wouldn't worry about it, It dosnt seem accurate. It keeps telling me my levels are low. I got tested at the doctors and all good. The lowest readings I got at the doctors was still higher than the highest readings I have ever got on fitbit.
