Please help!
Accessing exercises quickly is important. I like running but the 'run' button is hidden under 'more' and I have to scroll down the alphabetical list to get to 'run'. It's frustrating. 'Walk' is the only preinstalled exercise on my fitbit. Is there a reason for this and can I change this to have 'run' at the top.
Best AnswerHello @SineadT and welcome to the Community. As you use the Exercise app, your list will divide itself into Recent and the rest of the list. Run will go to the top of the list after you use it. My Sense 2 stores up to 5 Recents at the top of the list. I suspect your Inspire 3 will work the same way.
Laurie | Maryland
Best AnswerHi, @SineadT , if you are starting your runs from the Fitbit itself by launching the exercise app, then the activity you use the most (or Fitbit detects most often) should move to the top of the list. So if you go to “more” and select “run” the next time you launch the exercise app on your Fitbit, “run” should be at the top. Each time you track an exercise the one you most recently tracked should appear at the top of the list. Eventually you can have up to six (I think!) exercises above the “more” button, and how these will be ordered will depend on when they were last chosen. Once you have more than 6 above the more button, the most recent one you tracked will be added to the top, and the least used will drop into the more section. This was a change after recent updates. I hope this makes sense!
Short answer, track your run, next time it will be first on list, above walk, and above the “more” button.
Welcome to the Community Forums!
Best AnswerHi, I was in the settings and chose the exercise shortcuts. It made no difference but choosing run from the tracker itself means that run is now showing. Thank you for your time. Much appreciated.
