09-12-2023
14:58
08:33
09-12-2023
14:58
08:33
Hi everyone,
The screen began to “merge” several images
(clock / timer)
While displaying at an irregular frequency,
Unable to use buttons,
Nor even to restart,
Plugging in the watch has no effect,
After a few hours, everything is inactive.
Something is damaged (for no obvious reason)
Please indicate the procedure in this case,
I'm so confused !
(bought less than 4 months ago)
Best Answer09-13-2023 03:20
09-13-2023 03:20
Hi, @Dharmite, Welcome to the community, Allowing your attempt to restart has failed you should try to check the state of charge in your Inspire 3. If you can still sync your Inspire 3 with the Fitbit app on your phone you will see the SOC in the top right corner of the "Today" screen next to a battery icon. If you are not able to sync you may have a flat battery, Why isn't my Fitbit device's battery charging? provides advice. In my experience, your Inspire 3 will need to be on charge for up to 60 minutes before there is a sign of life.
If you can change the clock face in the Fitbit app on your phone, do so, you can always change it back later. This sometimes resolves this kind of problem.
If you are still stuck talk to "Customer Support" using the chat facility or phone for a prompt response, It's a good move to note the steps you have taken and the results so you can brief the agent clearly and allow them to resolve your issue. I note your Inspire 3 is only 4 months old, depending on where and when you bought it it will still be under Fitbit's warranty you should have this information at hand when you make your call.
I hope this helps.
Cheers
Gr4ndp4 | UK
09-15-2023 00:45
09-15-2023 00:45
