Inspire 3 screen is unresponsive
Slight vibration when button held down while on charger but face is blank and no app connection.  It appears to have died.
Bought 27 Dec 2025.
6 REPLIES 6
Hi @Williamschubert    Please contact Support  for more help, especially if it involves a device under warranty.
Laurie | Maryland
Mine is doing the same thing. It has 91% battery but the screen is not coming on, It vibrates when I touch it.
Welcome to the community forums @Williamschubert @10jenn08
Thank you for sharing with us the information regarding the difficulty that you are experiencing with Inspire 3.
Do you see a green light on the back of the device?
If you see the green light on the back is lit, but the screen isn't working, please try the following steps:
1. Sync the device in the Fitbit app.
  • From the Today tab in the Fitbit app, tap Devices.
  • Chooose the Inspire 3.
  • Tap Sync Now.
2. Check for available Firmware updates.
  • With the Fitbit device nearby, open the Fitbit app (make sure the Fitbit device is charged).
  • Tap the Today Tab > Devices > your device.
  • Tap Update (This option only appears if an update is available).
Follow the on-screen instructions: Keep the Fitbit device close to your phone during the update. When the update starts, a progress bar appears on the device and in the Fitbit app until the update is complete.
3. Charge the device:
  • Double-check the connection: Ensure secure connection to the charging cable and that the cable is plugged into a working USB port (computer or UL-certified wall charger).
If these steps don't work:
4. Restart the device: Keep in mind that your data won't be deleted: How do I restart my Fitbit device?
5. Changing the clock face via the Fitbit app can sometimes resolve a black screen issue:
  • Open the Fitbit app.
  • Choose Device Settings.
  • Navigate to the clock face options and try selecting a different clock face.
Mine was fine until I changed my clock face now it’s totally blank!!!!!
Not me of this worked and I can’t go to settings on my device when it’s blank.
I went through support and was well taken care of.  I received a replacement last week.
