04-06-2025
16:10
06:34
04-06-2025
16:10
06:34
I picked a new clock, face and synced and my watch face does not light up. Can’t see anything. What should I do? Can’t find anything in the Help section.
Best Answer04-07-2025 06:37
04-07-2025 06:37
Hi there, @Twwin2x2. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that the screen wake on your Inspire 3 is not working properly. I understand your concern, I will do my best to help you with this!
It could also be possible that your Inspire 3 is in sleep mode. When the sleep mode setting is on:
To turn off Sleep Mode, swipe down from the clock screen. Tap a setting to adjust it. . For more information, see How do I navigate my Fitbit device?
If the above doesn't describe your issue, please go to your quick settings and check that screen wake hasn't accidentally been turned off. swipe down from the clock screen again and tap the setting to adjust it. Change whether the screen turns on when you turn your wrist.
