10-21-2025
09:54
16:24
ManuFitbit
10-21-2025
09:54
16:24
ManuFitbit
Out of nowhere my Fitbit stopped working. After a shower is wouldn’t stop vibrating. It eventually died and I charged it with my computer to help reset it. The screen still won’t respond and my Fitbit will not update. I have tried everything! I forced restarted my phone, the app and the Fitbit. I turned the Bluetooth on and off. Unpaired and then paired the device with my phone again. Tried connecting it to the computer but with the new Google format I can’t see if anything synced. I am able to change the face of the clock so the Fitbit is still connected somehow but it will not swipe or update. I don’t know what else to do. Considering leaving the Fitbit brand after 10 years. Any help would be appreciated!
Moderator edit: clarified subject.
Best Answer10-21-2025 16:23
10-21-2025 16:23
A warm welcome to the community @CassMack.
Thank you for providing the information about the issue that you are experiencing with your Inspire 3. Sorry to know the difficulty.
I understand what you've done so far to get the device working again.
However, I'd like you to confirm that you tried the restart as indicated below:
Best Answer10-22-2025 04:51
10-22-2025 04:51
Hi ManuFitbit, this may not be the same issue, but I just cannot find any solution. HelpChat is closed; other related topic chats are all closed. I hope you can shed some light on how I can keep using my Fitbit after it was disconnected, since I needed to migrate my Fitbit account to a Google account. It was simply disconnected and not syncing. Thank you for your insight.
Best Answer10-22-2025 07:42
10-22-2025 07:42
Yes, I have tried this multiple times as well. No luck.
10-23-2025 05:13
10-23-2025 05:13
It's a real shame, isn't it? I am disappointed that my 11-year Fitbit journey ends abruptly like this. Sayonara!
