09-06-2024
05:43
08:54
09-06-2024
05:43
08:54
Fitbit went flat. After charging it only displays the clock page. Swiping up or down has no effect even after syncing with the app.
Hi there, @vbeard. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Inspire 3 is still stuck on the time screen. I understand your concern, I will do my best to help you with this!
Please check if your Inspire 3 is on "Always-On" display mode as this feature will only show you the time on the main screen all the time, unless you press the button of your Fitbit device to see other features and stats. To turn it off, please follow the steps below:
If the above doesn't describe your issue, please try the steps below:
If the above doesn't work, please restart your Fitbit device as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
