03-24-2023
05:59
16:27
JuanFitbit
03-24-2023
05:59
16:27
JuanFitbit
My son bought me the new fitbit 3 and im trying to sync it with my acc but its not happening i also have a luke fitbit tht is sync to my acc and i cant get it off my acc how do i take off the luke and synch fitbit3
Best Answer03-24-2023 06:51
03-24-2023 06:51
I assume you are talking about the Inspire 3 and the Luxe, though I guess it doesn't really matter.
When you add the new tracker (Inspire 3) via "Set up a Device" in the phone app, it will say something like 'I see you already have a Luxe set up. Do you want to replace this? '
Just answer 'yes' and Fitbit will take care adding the new device and removing the old device for you.
But before you do this, you should do a sync with the older device to make sure all your data gets to the Fitbit database before switching.
03-24-2023 06:49
03-24-2023 06:49
Hi, @Lisakane, welcome to the community, I'm a bit confused as to your present Fitbit device and assume your new device is an Inspire 3. You can only have one device paired with your Fitbit app. On your Fitbit app "Today" screen touch your icon in the top left corner>set up a device>select Inspire 3 and follow the instructions (it replaces your present device with the Inspire 3). Before you start sync your present device to preserve your data.
You may find this video a useful step-by-step walkthrough.
I hope this helps but if you are stuck please post here again.
Cheers
Gr4ndp4 | UK
03-24-2023 06:51
03-24-2023 08:08
03-24-2023 08:08
