Inspire 3 vibrations
ANSWERED
I get a strong vibration to notify me when I'm getting zone minutes, which I care nothing about. But unless I'm really still, I can't feel the vibrations to notify me to move every hour, which I really do want to feel. Is there a way to fix that?
1 BEST ANSWER
Accepted Solutions
Hi, @Pridel , welcome to the community, you can adjust the intensity of vibration in the settings of your Inspire 3 and turn off the AZM notifications if you wish.
On your Inspire 3 swipe down from the clock screen to and touch settings>swipe up to AZM notifications where there is an off/on slider, adjust as you need>swipe up again to and touch "vibration" to toggle between normal & strong. Once these settings are as you wish squeeze the sides of your Inspire 3 to return to the clock screen. It would be a good time to sync your Fitbit app on your phone.
So far as vibration intensity is concerned this is quite a small device and there are limits to how strong the "Strong" setting is.
I hope this helps but if you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
2 REPLIES 2
Cheers
Gr4ndp4 | UK
I already have vibration on strong. My problem is that the AZM strong is much stronger than the hourly notification strong. Or maybe it just lasts longer. At any rate, it is always noticable, whereas the hourly move notifications are easily missed.
But thanks, I turned off AZM notifications.
