03-25-2023 17:38
03-25-2023 17:38
My Inspire 3 says it’s charging when I plug it in. Then it keeps vibrating and dropping the battery percentage down? It keeps restarting and won’t charge properly. Really need help. :0(
16:20
10:26
03-26-2023
16:20
10:26
@Shazz0313 , A warm welcome to the Community! Thank you for your message.
Have you tried using another USB port, adapter or wall socket?
If you are using a quick charge wall adapter, try using a normal charge one.
This and more tips can be found here: How do I charge my Fitbit device?
and here
Why isn't my Fitbit device's battery charging?
16:20
10:26
03-26-2023
16:20
10:26
and here
Best Answer03-29-2023 02:52
03-29-2023 02:52
Thanks for the response. The problem was solved by using a different socket. Thanks
03-29-2023
10:00
10:19
03-29-2023
10:00
10:19
@Shazz0313 , Thank you for keeping us updated.
I'm glad that with the socket change everything is working again.
Please visit our discussion forums. There you will find several users who are interested in fitness, healthy eating, or better sleep and share lots of tips. They will be happy to meet you there.
Best Answer05-07-2023 10:33
05-07-2023 10:33
My Fitbit won’t charge or turn on or anything idk why it just was charging and now it stopped and won’t turn on
11:46
10:30
05-07-2023
11:46
10:30
@xavier135gg , A warm welcome to the Community !Thank you for your message.
If you already tried the steps described here:Why isn't my Fitbit device's battery charging?
then leave the Inspire 3 to charge for at least 30 minutes and then try restarting it, by connecting the Inspire 3 to the charging cable.
Best Answer05-07-2023 12:41
05-07-2023 12:41
13:35
10:29
05-07-2023
13:35
10:29
@xavier135gg , Thank you for your reply. I've informed our team and they'll be more than glad to help you further via email.
You'll receive an email soon.
Best Answer05-07-2023 22:38 - edited 05-08-2023 04:00
Hi @xavier135gg,are you using the proper charger that came with the watch, if not use that, or order one off fitbit.
