05-02-2023
06:58
11:32
05-02-2023
06:58
11:32
Hello,
for the past two nights, my HRV is at a 0, which is not accurate. How can I reset HRV feature, or is this a software issue? My 02 sats isn’t working either.
No issue with other features. Sleep is 8+ hours.
05-02-2023 17:10
05-02-2023 17:10
Hi @Danahop -- both metrics can be affected if you aren't getting good contact with your skin, so you might try adjusting the band. Also restart your device, (swipe down until you get to settings, and then swipe up until you get to restart). Hopefully that squares it away. Let us know how it goes.
Scott | Baltimore MD
05-02-2023 17:10
05-02-2023 17:10
05-06-2023 07:53
05-06-2023 07:53
Thank you! It’s working now.
