07-23-2024 15:09
07-23-2024 15:09
replacement wristband for inspire 3, buy on Amazon?
Best Answer07-23-2024 16:47
07-23-2024 16:47
Hi @Minnow32 you can get the band from Fitbit's Store or you can find local retailers who carry them. Amazon is fine, but be sure the band is for the Inspire 3.
Best Answer07-23-2024 16:59
07-23-2024 16:59
Best Answer07-23-2024 19:21
07-23-2024 19:21
Oh, then that's an easy fix. I used to have a band and used a pony tail holder (silicon type rubber band) to hold the strap in place. Maybe you could find a silicon band at a dollar store, which come in many colors and see if it works for you. IF you're under warranty, you should get with customer service.
Best Answer07-24-2024 03:45
07-24-2024 03:45
