I bought my inspire 3 11/26, since receiving I've had multiple issues.
The heart rate monitor seems to constantly have a mind of its own (it just tracked me at 165 and I wasn't even wearing it), the battery doesn't seem to last long, settings seem to reset themselves (turned always on off, it was back on for a bit then went back off), data not syncing or showing incorrectly...
I'm not sure if these are glitches with fixes or if this one might be a lemon in need of replacement.
Best AnswerLooks like the latest version. See what customer support says.
here are the support contacts I've gleaned over the years on the forums.
when there is someone available, chat is an option. Phone or X/Twitter works well, too.
https://myhelp.fitbit.com/s/support?language=en_US
Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
Best AnswerUpdate:
Support- ".: Our current version is 4.06" ".: If the update is not available in the store then you need to uninstall and reinstall the app."
I did so and contacted them again as nothing changed.
Support- ".: I can see on the system that your app is not up to date yet, please wait until tomorrow to check if the update is available or please try tomorrow to uninstall and install the app again, please keep the case number to continue assisting you with your case."
I asked if the new version be released in Google play tomorrow...
"Agent: Yes that is correct"
_____________________________________________
So that's where this is at currently, no solution yet.
