08-20-2024 20:18
08-20-2024 20:18
Before the update, while tracking a walk I saw distance, current pace, and average pace. Now distance is replaced by time of day. Time of day also appears at the bottom. I assume this can’t be customized. Is there a way to suggest to the developers I want distance walked back?
08-21-2024 10:33
08-21-2024 10:33
Hi, @Aclayjar May I suggest you consider the following? Once you have the exercise display recording on the screen of your Inspire 3 tap the screen to see the display toggle through the steps, distance etc. Try it out and let us know how you get on.
Cheers
Gr4ndp4 | UK
08-21-2024 07:44
08-21-2024 07:44
Hi, @Aclayjar, welcome, check out this thread. Inspire 3 is not tracking my distance accurately - Fitbit Community
Cheers
Gr4ndp4 | UK
Best Answer08-21-2024 08:18
08-21-2024 08:18
Hi,
thanks for answering but that’s not my issue.
distance is not shown at all during tracking. The display defaults to showing time of day.
Best Answer08-21-2024 08:24
08-21-2024 08:24
Hi, @Aclayjar, how do you start the record of your walk, do you use the settings on your Inspire 3 or allow it to start via the auto-recognize feature? Which ever one you are using try the other, let us know how you get on.
Cheers
Gr4ndp4 | UK
Best Answer08-21-2024 08:46
08-21-2024 08:46
It doesn’t make any difference.
On the device, when I walk it shows
time of day
pace
elapsed time
time of day
after I work out and since the app I get the distance, but I’d like to know during.
Best Answer08-21-2024 10:33
08-21-2024 10:33
Cheers
Gr4ndp4 | UK
08-21-2024 11:53
08-21-2024 11:53
Yes, that works. Thank you!
however, it’s not saved as my preference, I have to set it each time.
also , I have the option of having the time of day appear 3x on the screen. 😜
I’d still like to see this featured changed on an update
Best Answer08-22-2024 00:32
08-22-2024 00:32
Hi,
sorry but how do you do that exactly? When I start the activity recording I don’t have any toggle I can only start and stop the activity
Best Answer08-22-2024 06:06
08-22-2024 06:06
Hi, @Aclayjar if you select your preferred metric and then just leave it & the display should remain the same each time you initiate the automatic screen wake by flicking your wrist.
I hope this helps.
Cheers
Gr4ndp4 | UK
Best Answer08-22-2024 06:08
08-22-2024 06:08
Hi, @Matildes, I apologise, I should have been clearer, to toggle the display just tap the illuminated screen.
I hope this helps.
Cheers
Gr4ndp4 | UK
08-22-2024 06:21
08-22-2024 06:21
Oh yes clear now, many thanks!
However, for the running activity is not possible to have both KM and pace at the same time? It used to be possible before the update
