Before the update, while tracking a walk I saw distance, current pace, and average pace. Now distance is replaced by time of day. Time of day also appears at the bottom. I assume this can’t be customized. Is there a way to suggest to the developers I want distance walked back?
Hi, @Aclayjar May I suggest you consider the following? Once you have the exercise display recording on the screen of your Inspire 3 tap the screen to see the display toggle through the steps, distance etc. Try it out and let us know how you get on.
Cheers
Gr4ndp4 | UK
Hi, @Aclayjar, welcome, check out this thread. Inspire 3 is not tracking my distance accurately - Fitbit Community
Cheers
Gr4ndp4 | UK
Best AnswerHi,
thanks for answering but that’s not my issue.
distance is not shown at all during tracking. The display defaults to showing time of day.
Best AnswerHi, @Aclayjar, how do you start the record of your walk, do you use the settings on your Inspire 3 or allow it to start via the auto-recognize feature? Which ever one you are using try the other, let us know how you get on.
Cheers
Gr4ndp4 | UK
Best AnswerIt doesn’t make any difference.
On the device, when I walk it shows
time of day
pace
elapsed time
time of day
after I work out and since the app I get the distance, but I’d like to know during.
Best AnswerHi, @Aclayjar May I suggest you consider the following? Once you have the exercise display recording on the screen of your Inspire 3 tap the screen to see the display toggle through the steps, distance etc. Try it out and let us know how you get on.
Cheers
Gr4ndp4 | UK
Yes, that works. Thank you!
however, it’s not saved as my preference, I have to set it each time.
also , I have the option of having the time of day appear 3x on the screen. 😜
I’d still like to see this featured changed on an update
Best AnswerHi,
sorry but how do you do that exactly? When I start the activity recording I don’t have any toggle I can only start and stop the activity
Best AnswerHi, @Aclayjar if you select your preferred metric and then just leave it & the display should remain the same each time you initiate the automatic screen wake by flicking your wrist.
I hope this helps.
Cheers
Gr4ndp4 | UK
Best AnswerHi, @Matildes, I apologise, I should have been clearer, to toggle the display just tap the illuminated screen.
I hope this helps.
Cheers
Gr4ndp4 | UK
