10-28-2023 03:33
10-28-2023 03:33
I am having a real issue with my Inspire 3. It is no longer recording my sleep score. It is also reluctant to give me steps score too. I have a new iPhone 15 Pro but that shouldn’t make a difference. Is anyone else having this problem and have managed to sort it out? At the moment it is only good for telling the time.
10-28-2023 12:42
10-28-2023 12:42
Welcome to the forums @tfoxon57.
I appreciate you taking the time to share this inconvenience with me in the community.
Keep in mind that you must see sleep stages in order to see a sleep score. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
If you see sleep stages but don’t see a sleep score, please note that it may take a few minutes for your sleep score to appear. In addition, for better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually and make sure to keep the Fitbit app and the devices' firmware updated to the latest version available.
The Inspire 3 may need some days to collect some information (particularly regarding heart rate) and provide sleep score, sleep stages and other data. Make sure that you've also tried the restart procedure described here and check if you continue to experience the same problem.
In case the problem is related to the Fitbit app, please try the following as well:
10-28-2023 12:42
10-28-2023 12:42
