Hi, @Audrey1206 , yes you definitely can! This is something you set in your app. From the opening screen of the app click on the gear icon top right. On the next screen find “App settings” and then choose “Units”. Select your Units and then exit. Make sure you sync your Fitbit whenever you make any changes in the app so the changes are reflected on your wrist.
I hope this helps. Welcome to the Community Forums!
Best Answer@Audrey1206 I want to clarify something about Fitbit's pace notation that is confusing to many users, especially metric distance users. Fitbit's pace notation is 00' 00". This is minutes and seconds, not feet and inches. And your reported pace is always in your distance unit. So if you run your 5k in 28 minutes and 15 seconds, your Fitbit will report your pace as 05' 39" and your elapsed time as 28:15.
Laurie | Maryland
