10-27-2023 11:54
10-27-2023 11:54
I’m so frustrated!!! For the last week or so my sleep data says I’m only sleeping between 1 and 2 hours a night! I know I don’t get enough sleep but this is wrong! Tracking my sleep is 1 of the main reasons I got an Inspire 3. I’ve tried all the tips I could find. 😢
10-28-2023 10:56
10-28-2023 10:56
Welcome to the forums @Gabee01.
Sorry to know that. Thank you for providing the details regarding this issue with your device and the attempts to fix it by your own.
Even though you did the steps already, please confirm that you have complete a restart procedure following the steps listed here.
Please keep in mind that there are some factors that may prevent your tracker from recording your sleep. Please make sure of the following:
Please wear your device on your non-dominant hand and monitor it for the next few days. In the meantime, for the nights that don't have sleep data, you can manually log your sleep by going to the Fitbit app.
Best Answer11-02-2023 12:15
11-02-2023 12:15
11-02-2023 12:30
11-02-2023 12:30
It’s absolutely ridiculous!!! Mine does the same
11-03-2023 07:21 - edited 11-05-2023 04:51
I am having the same problem. Last night I had a wonderfully long sleep but FitBit recorded 2 different sleeps with about 1 1/2 hours between the two. Two different sleep scores. I didn't have a big gap in my sleep last night. Why did Fitbit decide that I was awake and why did it split the sleep into two blocks with two different sleep scores!!!!! Argh.
Update: November 5. Fitbit didn't properly account for the change in daylight savings. It completely ignored that extra hour. (I accounted for sleep start to sleep end, less the time awake.)
11-05-2023 04:20
11-05-2023 04:20
I’m disappointed to read that this is a problem with Inspire3 I have just started to use mine and it only records the first section of sleep, once Iv woken or got up, it doesn’t record any more. So disappointed!! Will it help if I change sleep tracking from Normal to Sensitive?
11-05-2023 06:32
11-05-2023 06:32
I have mine set to sensitive. It's worth a try. I hope this helps, Pirribee.
Best Answer11-05-2023 07:25
11-05-2023 07:25
Same with me!
I used to have an inspire 3 that I gave to my mum that did not have this problem. Bought another one for myself and it hasn’t logged a single night correctly. Most nights it just doesn’t log any data at all and I need to manually enter it in! So frustrated!
11-05-2023 09:02
11-05-2023 09:02
Me, too. It is super annoying.
11-07-2023
12:13
13:36
ManuFitbit
11-07-2023
12:13
13:36
ManuFitbit
I just tried changing my settings to Sensitive- it’s been 2 or 3 days, but no change yet.☹️
Ten days later, I don’t see any difference since changing settings to “sensitive.”😔
So, last night I went to sleep at 2am, got up shortly after 5am for restroom back to sleep until 8:15. My Fitbit registered sleep at 1:57 am, awake at 4:56 am? and that’s it! So, since I was aware of times, I tried to edit the log and make it end at 8 am. It did, with the entire space full of red and blue vertical lines! How does that help?
11-20-2023 03:18
11-20-2023 03:18
