Hi, @SunsetRunner , how long have you had your Fitbit? Has it ever given you detailed sleep?
What you describe can be caused by a number of factors:
- Your Fitbit needs to detect your heartrate consistently through the night in order to give you detailed sleep info, including sleep stages (deep , rem, light, etc). If it cannot detect your heartrate your sleep pattern may be broken and split into parts. Sometimes this occurs if you are sleeping in a position that means your wrist is significantly flexed or if the band is too loose. Try wearing it snugly, but not so tight that it restricts you.
- You will not get sleep stages/ detailed sleep info if you sleep less than 3 hours. As you mention that your sleep recordings are broken into 3 parts this may be why you did not get sleep stages.
- You will not get sleep stages/ detailed sleep info if you start sleep manually. You must allow sleep to be detected automatically.
For more information please see the help article on how to track sleep with your Fitbit.
Hopefully taking this info into account you will be able to get your detailed sleep information moving forward.
Welcome to the forums!
