08-29-2024 03:26
08-29-2024 03:26
Since yesterday i have a inspire 3.
the first morning a beautigul registration, with deep sleep and light sleep and more. And a score.
this morning no score and only registration with awake , sleeping etc 🙈🙈🙈
Best Answer09-09-2024 20:19
09-09-2024 20:19
Hi, @Ineke66 , what you saw on day 1 is exactly what should happen. On day 2 you got “simplified sleep”. It sounds like this may have happened to you because it could not consistently read your heart rate. For best results wear the band snuggly, but not overly tightly on your wrist. Note that if you have a tendency to sleep with your wrist in a very flexed position then it may not be able to get a consistent reading.
As your device is very new, I would recommend experimenting for a few days with how tight and how high up you wear your Fitbit (it should be snug but not tight, and just a little above your wrist bone). Also you might even want to try wearing it on the opposite wrist during sleep.
