12-28-2024 07:36
12-28-2024 07:36
How do I correct the time on my fitbit
Best Answer12-28-2024 08:14
12-28-2024 08:14
Syncing with the mobile app is supposed to correct off time.
Best Answer12-28-2024 11:44
12-28-2024 11:44
If not ?
Best Answer01-04-2025 16:16
01-04-2025 16:16
You just have to sync with the mobile app. However, if this doesn't work, make sure:
If syncing can't change the time, try restarting both your phone and your watch. Also check you have installed all updates.
