Using Inspire 3 in water
ANSWERED
What does the water lock icon look like on Inspire 3?
1 BEST ANSWER
Accepted Solutions
@Marcykay it looks like this. It's a water drop with "Water Lock" scrolling across underneath.
 From the main screen on the Inspire 3, swipe down until you see that water drop image. Tap on that and then, when it prompts you to, double tap hard to turn on the Water Lock. Then, there will be a message on the main screen to indicate that Water Lock is engaged. If you double tap hard again, you'll get a prompt to double tap again to dismiss Water Lock.
Community Council Member
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
1 REPLY 1
