Hi, @Colo1402 , welcome to the community. If you swipe sideways to "Exercise" from the clock face then swipe up to & touch "Run" you will see the start arrow with a little chevron at the bottom, swipe up to set a goal & adjust other settings.
I'm not a runner so do not know if this triggers a vibration, In any event in the Fitbit app>today screen touch the device icon in the top left>Lux>Notifications>app notifications>Fitbit. If this does not work, in addition, try setting the Vibration setting slider in the on position.
Page 33 of the manual tells us -
Track a daily activity goal
Inspire 3 tracks your progress toward a daily activity goal of your choice. When you
reach your goal, your tracker vibrates and shows a celebration.
I hope this is helpful.
Cheers
Gr4ndp4 | UK
On the web interface, click settings, then Inspire 3. Click Edit for Exercise Cues, under Run, select Automatic, Kilometers, 1KM.
If Run does not show as an option, add it in the section just before Exercise Cues (Exercise Shortcuts).
On the app, select the Inspire 3, then under Exercise Shortcuts, select Run, Show Laps (Auto), Lap Type (Kilometers), Lap Every (1.0 kilometers).
