I recently got an Inspire 3 to replace my Alta HR. I was chose this one because it has sp02 sensor like the more expensive models. In the instructions it states I can search for sp02 in the gallery to find a clock face that includes sp02 data. But when I go to the gallery, there is no way to search. I do have the app installed and I can scroll to the info but I was expecting to be able to add a clock face that included it. Has anyone been able to do this? Is it just me?
Best AnswerHi, @campbellonh , the SpO2 “clock face” is a little different from the others (and doesn’t actually replace your regular clock face - it just allows your SpO2 levels to be checked over night). You will find it in the apps section.
You can find it by clicking on the person photo/icon on the top left of the opening, Today, screen. On the next screen click on the picture of your Inspire 3 and then click on Gallery. There you need to click on Apps rather than Clocks and you can install it there. Be sure to sync your Fitbit whenever you make any changes in the app.
Please note that the SpO2 app will not give you a continuous or spot check view of your SpO2 levels. It only detects levels during sleep and you will be able to check the levels overall level on your Fitbit in the morning, and see more detailed information in the app.
I hope this helps. Welcome to the forums!
