Lots of fantastic watch faces but could I ask someone who has the knowledge (I cannot connect my fitbit ionic to my current computer) to create a basic/classy simple digital watchface with two lines of information both in the largest practical sized typeface. An upper line with the time and the lower line with the one of the other stats. By tapping the lower line it changes to anothe stat such as: heart rate, steps, date etc.
I currently use Argle which is nice and classy and I can see the time, but have to put my glasses on to see the tiny stats. The lower stat changing when i press it.
A wonderful watch, loads of great stats but problematic for me and I presume many over 50 yo.
12-07-2017
12:30
14:36
12-07-2017
12:30
14:36
@Shortsighted Welcome to the Fitbit Community! Thanks for your feedback! There was an update for Ionic a couple of days ago. This update includes new clock faces, bot from Fitbit and third parties. New clock faces will be added frequently. I'm sure you will find what you are looking for there, as there are a lot of different ones! Please update your Ionic. Take a look at this post for more details on how to do this.
Also, is your Ionic paired to your account? If it is not, please check this article to get the steps to set it up properly.
Hope this helps. Keep me posted! ![]()
Best AnswerHi,
I have the update and see lots of watch-faces – but not one that delivers what I suggested above.
Although the only way to try the watch faces is by loading them. Better descriptions are required.
You have tried to help by checking I have done the basics – which I have. I really need some help finding the watch face that is good for someone who does not want to put glasses on to read the watch stats. Which watch face do you suggest?
Cheers,
Phil
i use activstatface which i find isn't to bad.
06:26
13:45
12-10-2017
06:26
13:45
@Shortsighted Thanks for your reply and for updating your Ionic! In that case, I'd recommend the "Retro Sunset" clock face. This one will show big stats! You should be able to see them with no problem. Try downloading that one to your watch and try it out!
Let me know how it goes! ![]()
Best AnswerHi,
Many thanks for all your replies but sadly non allow the HR and stats to be seen. They are presented in a small font.
I would have probably used the garish "Retro Sunset" but is does not show the HR. Sort of a must for a heart rate monitor.
Please a simple watch face with large font for stats as suggest in my first post.
