10-01-2017
17:19
08:50
SilviaFitbit
10-01-2017
17:19
08:50
SilviaFitbit
My active minutes went suddenly went from 28 to 10. I ran a 5k today and that shows up under excersize for 25 minutes but my tracker and my dashboard now say 10 active minutes.
It's great to have you here @juliep3644! I would like you to double check that there are no manually logged activities that could be deleting the active minutes that you previously had.
Does the active minutes disappeared right after you synced your tracker? Were you seeing 10 active minutes in your Ionic as well? Is the other data showing less as well or just active minutes? Do you still see the same 10 active minutes?
Keep me posted.
Best AnswerI had the exact same issue.
I have since checked the activities as mentioned and my walk is registered there but still no active minutes.
It displayed 31mins on my watch then when syncing to my phone went to 0.
Please help as I really need to record my active minutes.
Thank you
