Was missing that bright two tone distinction as the grime began to build up.
Overcame the cleaning challenge on the hex holes...
Pick up a 99cent small paintbrush and lay on a Clorox wipe, push the bristles through the bracelet holes to wick up the moisture from the wipe, and gently brush in a circular motion up and down the band. After grime is dislodged wipe down with a damp lint free towel and the white returns!
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
