07-13-2021
20:33
09:40
SilviaFitbit
07-13-2021
20:33
09:40
SilviaFitbit
Done a factory Reset with the guy from Fitbit as there was un update pending...
Now when I do the recommended update it will not sync.
I also keep getting the Calibration setup come up on the watch and that will not complete either
Any one else with this problem and know how to slve?
09:42
11:19
07-14-2021
09:42
11:19
@Altai13 It's great to see you in our Fitbit Community. Regarding the firmware update and setup issues that your Fitbit Ionic has experienced, I appreciate the time spent trying to get it resolved before contacting our forums.
I noticed that you contacted our Support team and they assisted you via chat. In case the issue persists, contact them with the reference number they provided and they'll be happy to follow up.
See you around.
09:42
11:19
07-14-2021
09:42
11:19
@Altai13 Welcome to the Fitbit Community. Thanks for the details mentioned and the troubleshooting performed with Support.
I'd like you to restart your Ionic and if follow this procedure to set it up to your account again. If you receive any error message, follow this syncing troubleshooting.
Take into consideration that if you have a case created with our Support team, it's recommended to continue the communication with them, this to avoid any confusion.
Hope this helps.
