02-07-2018 09:31
02-07-2018 09:31
My silent alarm keeps failing to work I set it on daily repeat and it works but not the next day and when I try it at the present time it will work but not on the repeat mode.
Best Answer02-08-2018 22:05
02-08-2018 22:05
When setting it up you see the word repeat. Then you have to select the days you want it to repeat, then save.
Best Answer02-09-2018 08:46
02-09-2018 08:46
