Best AnswerYou can also do it directly in your Ionic. Click on the alarm icon. select new alarm ( at the bottom) activate alarm. Don’t forget to click on “ every day”, if this is what you need.
Best AnswerSorry. I don't understand what you mean by " I click my device image". Can you be more precise?
Is your Ionic already set up? Here is also the user manual, it might help you.
https://staticcs.fitbit.com/content/assets/help/manuals/manual_ionic_en_US.pdf
Best AnswerI would just do it on the device itself. Swipe right and you will see your apps. Keep swiping right and you will see the "Alarms" app. Tap it and it will ask you what time you want to set it for. Swipe up or down on the numbers to find the correct time, then tap the time and hit the back button. When that time comes, the watch will vibrate and say "Look Alive". When it does, tap the checkmark in the lower right hand corner and then take your pill.
one cruise ship at a time!
