Since yesterday I have been getting a to continue using classic analog please visit kzl.io/classics and enter code which is numeric. Anyone else seen this? I have unpaired and paired multiple times along with resetting and uninstalling fitbit app. Multiple time I've only had my ionic for a week!
Best AnswerDid you install a custom made watch face? Seems to me that you got a free trial of the app and now to continue using it you need to pay the creator of the app. If you don't want to pay then download another watch face that is free to use or use the Fitbit created watch faces (I'm only guessing here but that is the gist of what I got after using google for the address you typed in)
Best AnswerOh well I used what was showing for the faces I'll change it and see if that helps. I'm also getting the k-pay error and all that I've done hasn't fixed that issue either
Best AnswerThank you so much. That has fixed it. I appreciate your help. I'm also getting the k-pay error and all that I've done hasn't fixed that issue either
