11-14-2017 19:43
11-14-2017 19:43
Does the Ionic have a feature where it can automatically adjust your step goal based on your activity history? If not, would it be possible to add this feature?
11-14-2017 19:52
11-14-2017 19:52
@Brneyedflgrl wrote:Does the Ionic have a feature where it can automatically adjust your step goal based on your activity history? If not, would it be possible to add this feature?
Hi @Brneyedflgrl,
Not exactly automatic. But if you go into the 7 Day Summary in the app, it will give you a chance to adjust the goals from the previous week. Hope this helps.
03-12-2018 15:59
03-12-2018 15:59
That does not even remotely help. Other step trackers if you set to automatic it will adjust your daily goal according to yesterday’s steps. You don’t have to look and adjust anything.
03-12-2018 16:34
03-12-2018 16:34
@Doubleksdadwrote:That does not even remotely help. Other step trackers if you set to automatic it will adjust your daily goal according to yesterday’s steps. You don’t have to look and adjust anything.
Cool. Fitbit doesn't do that though.
03-18-2018 16:36
03-18-2018 16:36
Cool thanks for the heads up. Fitbit lost a sale.
