08-14-2018
05:42
11:16
SantiR
08-14-2018
05:42
11:16
SantiR
After a walk this morning my ionic battery was at 23% so I put it on charge for about an hour and it went back up to 84%.
After working for 3 hours I looked at my Ionic to see the time but the screen was dead. When I plugged it into the charger after trying to reboot it, it was on 0% battery! What's going on? I've had it for 3 or so months and I'm worried that there is an issue with the battery. I'm charging it up now and will update again tonight. Wish me luck!
Moderator Edit: Updated Subject for Clarity
08-15-2018
11:16
07:08
08-15-2018
11:16
07:08
@Rach77 I hope you're doing well! Thanks for reporting the situation you are experiencing with your Ionic's battery power.
Good luck! Is this still happening today? I'd recommend performing a restart on your Ionic first. Then, check these tips that can help on getting more battery power on your watch.
Hope this helps. Keep me posted! ![]()
08:35
07:08
08-16-2018
08:35
07:08
@Rach77 Thanks for your reply and for checking those tips. Thanks for the details too.
I went ahead and created a case with customer support in your behalf. Please keep an eye on your email inbox for next steps.
