07-05-2018 13:38
07-05-2018 13:38
Hi guys
I'm seeing massive battery drain on my s8 in the last few days, I'm getting device maintenence warnings about fitbit app it currently shows 37% battery usage since last charge on my s8. Also having weird sync issues with sms when I get TXT ionic the shows the last few TXT plus the latest.
07-05-2018 15:23
07-05-2018 15:23
Same thing happening on my BlackBerry keyone. Killed off my phone battery in hours.
Best Answer07-05-2018 15:47
07-05-2018 15:47
Similar problem on my Pixel 2 XL.
Three is a thread over at the Versa forum. It all points to the recent app update.
We need a hotfix soon!
Best Answer07-05-2018 19:52
07-05-2018 19:52
As pointed out in the Versa, Charge 2, flex, zip. and I'm not sure where else .since this is an Android related problem. Them main thread is on the Android Board.
07-20-2018 06:34
07-20-2018 06:34
this was fixed with the latest update to the app.
07-20-2018 06:48 - edited 02-11-2024 10:06
Hi everyone in this thread! As my friend @MasterSTIN mentioned, this issue is now solved.
Please make sure to update your Fitbit app to version 2.74.2 as it addresses the issue with the battery drain. You update the Fitbit app just as you would any other app on your device. If you’re unsure how to update an app:
If your apps update automatically, check the Recently updated or Up to date list to see if the Fitbit app was updated.
If you have any questions, please check the main thread that @Rich_Laue has shared above.
