06-25-2019
10:54
11:45
RicardoFitbit
06-25-2019
10:54
11:45
RicardoFitbit
Hi all,
All of a sudden, my Fitbit Ionic battery started to drain within a few hours. This is strange. Can you please assist on what can I do. I already performed a factory reset.
Thanks in advance.
Hi @Bonells thanks for bringing this to my attention, welcome to our Community Forums.
Seems odd that the battery of your Ionic is depleting within a few hours. Let me share with you that this specific model was designed to last 5 days, but the battery life also depends on how frequently you use its features. That said. I recommend you to charge your Fitbit with a USB port from a computer or a UL-certified outlet into the wall, then turn off all the features that you don’t use that much and check this help article for more tips and recommendations.
Keep me posted, I’ll be right here if you need anything else.
