If i press the button on the left fitbit accidentally the homescreen will show and stay on until I press it again and it would also blink. When this happens it drains the battery so I'll only get aday of use before it powers off.
Good morning, welcome to forums @Edgar716 , you are right not normal operation.
Try a product reset Edgar,
If still "sticking" screen on, narrow the issue by turning off auto wake feature:
Turn off the option to wake the screen when you turn your wrist:
If the issue persists, contact customer support chat direct and let them know what you have tried.
They are anxious to help.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
