01-25-2019 22:26
01-25-2019 22:26
Is anyone else finding the battery life on their ionic is lasting less than 24hrs now. Mine used to go 4-5 days before I had to charge. I did the app update 3 days ago and now I’m lucky if the battery lasts 24 hours
Best Answer01-26-2019 00:45
01-26-2019 00:45
Do you get a lot of notifications? The new update causes the screen to come on everytime you get a notification. People with a lot have been noticing their battery going flat quickly.
Helen | Western Australia
01-26-2019 02:05
01-26-2019 02:05
Hey Nelly, no I don’t get a lot of notifications, I had heard of this. My battery life reduction coincided with the latest app update three days ago
01-26-2019 03:33
01-26-2019 03:33
While longer than 24 hours my battery life has dropped from 5 days to 3 after the last update. Notifications turned off.
Best Answer01-26-2019 03:44 - edited 01-26-2019 03:47
@Steven1709 I had an issue some time ago with 5 days battery life down to 3. I let my battery drain down then fully charged it and performed several restarts in succession and it has been fine ever since. As a rule I always give my devices a restart after charging as I believe it makes for good housekeeping.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
01-26-2019 05:45
01-26-2019 05:45
Thanks Tony, I’ll give that a try
Best Answer01-26-2019 18:01
01-26-2019 18:01
Well I’ve tried all and it still drains the battery very fast. I’m barely getting 24 hours out of it now. When I took it off charge at 100% it dropped to 95% in less than a minute. All I get from Fitbit is the generic email responses about the battery only designed to last 24 hours. They don’t seem interested in the fact the product used to go 4-5 days before I had to recharge it. Since the app update on the 23rd of January which was supposed to increase performance issues, it has gone to garbage. It needs charging more often than my wife’s Apple Watch.
I don’t think I’ll get another Fitbit if this is the way they’re going now. Most of the chats on here seem to be complaints and when you read them, Fiibit just post the usual garbage, their product is definitely gone downhill
Best Answer01-27-2019 00:29
01-27-2019 00:29
@Mbalenz Thanks for trying, have you tried uninstalling and reinstalling the app to see if that makes a difference? Can I also ask if you are using an an official Fitbit watchface or a 3rd party one? And also just to elimiante do you have any apps installed on your Ionic and in particular anything new?
Tony | UK
Best Answer01-27-2019 04:46
01-27-2019 04:46
Mine hasn't gotten that bad, but it's only lasting at max two days now. And, you're right, it's only started after the app update.
Best Answer02-14-2019 23:31
02-14-2019 23:31
@Tony.rGood practice... I hadn't restarted my Ionic for a few weeks and after yesterdays charge it lost 45% overnight.. I normally lose only 0.51%/hr and get about 6.5 days with no GPS. I did a restart and that arrested the issue and I let it got for another 2.5 days and recharged at 27%.
In the past the restarting has arrested this sudden drain issue so I will no do as you do.. Restart after a charge.. Well done.
@Tony.r wrote:@Steven1709 I had an issue some time ago with 5 days battery life down to 3. I let my battery drain down then fully charged it and performed several restarts in succession and it has been fine ever since. As a rule I always give my devices a restart after charging as I believe it makes for good housekeeping.
02-15-2019 05:30 - edited 02-15-2019 05:30
@Colinm39 good to hear it worked for you. Since I've been restarting after every charge, I have never experienced any excessive battery drains and always manage 5 days use between charge cycles.
Tony | UK
