06-25-2018 15:43
06-25-2018 15:43
I purchased an iconic about four months ago. The battery life was excellent, however, in the last month I have noticed it recharges to 100% very quickly, but then the battery is totally dead about a day to 2 days later. I turned off all Day sync to see if that helps, but no such luck. Anyone else have this issue or any advice is greatly appreciated.
06-26-2018 03:45
06-26-2018 03:45
I am having the same issue and have had my watch for about the same amount of time. I haven’t had any luck in getting it to last longer. If you discover a magic trick let me know😉
06-26-2018 04:18
06-26-2018 04:18
Yes, same here. Either it's a software issue, or the battery in the Ionic has degraded very quickly. I suspect a software issue.
06-26-2018 06:55
06-26-2018 06:55
I am also having this issue in the last couple of days. I haven't updated to the latest firmware either so dubious that it is a software issue
haven't changed anything in my settings to cause it, the only thing that is different is that it is particularly hot here!
I have tried doing a hard reset and also restarting my phone in case it's something in my phone's bluetooth settings causing drain (i have all day sync turned on and always have). Also trying leaving the ionic in the charging cradle for longer even once it's hit 100% as it seems to be getting there very quickly but then also draining very fast. 10% drain in an hour and a half with only basic walking around....
