04-17-2019
20:23
19:54
RicardoFitbit
04-17-2019
20:23
19:54
RicardoFitbit
I have owned both the Blaze and Ionic and for the life of me.....cannot get them to give me an accurate step count or distance. I do a lot of repetitive arm movements, switched dominant and non dominant hands, calibrated, etc. None of it works. I'll hit 10,000 steps, but be no where near 5 miles. The best tracker was Fitbit One. I would wear it in my bra and get accurate readings. I've even worn it while wearing the Blaze or Ionic. Result - counts no where even close. Help!!!!!
04:12
08:54
04-18-2019
04:12
08:54
@Labgal319 I have moved your post to the Ionic forums where it will get more visibility (you posted in the Charge 3 forums) and hopefully more help.
In my experience, my personal 10,000 steps is usually around 4.15 miles. In order for me to get to 5 miles, I need to do roughly 12,000 steps. Stride length is personal, of course, but that's just to give you an idea.
20:01
08:54
04-21-2019
20:01
08:54
Hello @Labgal319 let me give you a warm welcome to our Community! I'm glad to give you a hand with your steps concern. Thanks for moving this post and for your suggestions @Heather-S, happy to see you again.
I'd like to share with you that Fitbit devices have a finely tuned algorithm for step counting. The algorithm is designed to look for motion patterns that are most indicative of people walking. If you wear a wrist-based device and move your body while keeping your arms still (or vice versa), you may see a slightly different step count than if you wear a device clipped to your clothing.
If you wear your device in a loose-fitting accessory such as a bangle or pendant, you may see a slightly different step count than if you wear a classic wristband. During workouts and sleep, we recommend wearing the classic wristband. Make sure the wristband fits securely but isn't too tight. I recommend you to check this help article for more information and details.
I'll be around. Let me know if you have any additional questions.
