The app keep saying I must cancel or restart Bluetooth and it's been working fine all along on the same Samsung phone
Hey there @xtshapa, thanks for stopping by! If your phone is managing multiple Bluetooth connections simultaneously:
These interruptions are typically caused by operating system and Bluetooth limitations. It's also possible that an app on your phone is causing the issue.
Since you have an Android phone, try these steps:
The API used in these apps makes it difficult for Fitbit to communicate reliably with your phone. Ford provides a list of apps but note that other companies may use the API as well.
If you keep having Bluetooth issues after reviewing what I posted above, please send me a picture of the message you're getting so I can go from there.
I'll be around!
I'll be around!
