10-17-2017 08:23
10-17-2017 08:23
Can the settings be set so that when I am running the watch will buzz at every mile split? I miss that feature from my old watch.
Best Answer10-17-2017 10:39
10-17-2017 10:39
Hi, @allan473, yes, you can do that. On your app chose your Ionic, then choose "Exercise shortcuts" . Scroll down to "show cues" and choose "automatic", next set your cues for "mile".
Be sure to sync your Ionic after making the change.
10-17-2017 10:39
Best Answer10-17-2017 12:41
10-17-2017 12:41
Thanks Julia.
Best Answer10-17-2017 12:57
10-17-2017 12:57
@Julia_G wrote:Hi, @allan473, yes, you can do that. On your app chose your Ionic, then choose "Exercise shortcuts" . Scroll down to "show cues" and choose "automatic", next set your cues for "mile".
I use the "Show Cues" function for every run, unfortunately I need to set it prior to every run; there should be a way to set it and forget it.
Best Answer10-28-2017 00:52
10-28-2017 00:52
Thanks, please fix this fitbit! If we set this we want it to buzz every run.
Best Answer10-28-2017 06:10 - edited 10-28-2017 06:10
@LollyG wrote:Thanks, please fix this fitbit! If we set this we want it to buzz every run.
Hey @LollyG, turns out we've all been fussing about something which isn't an issue; turns out you can set the notification interval from the Dashboard on Fitbit.com. I just changed mine to a mile and sure enough, the notification now buzzes every mile. 🙂
