Can Bootcamp track distance?
Hi all,
I regularly attend a military style bootcamp which combines a lot of running and body weight activities. I want to know what distance I have covered whilst doing this. I use the same short cut and one week it showed the distance and the rest it doesn't. How so I change this or find the kilometers?
Thanks
2 REPLIES 2
A warm welcome to the Community @SunsetRunner. Great to hear that you would like to use your Ionic to track your Bootcamp activity.
I added this exercise shortcut to my Ionic and it doesn't show distance. It only showed time, heart rate,  bpm max and calories burned. Please remove the shortcut and then add it back, it should always show you the same stats.
Go to your online Dashboard
- Click on Ionic
- Find exercise shortcuts
- Remove Bootcamp
Go to your Fitbit app
- Tap on Ionic
- Scroll down until you see Exercise shortcuts
After you've remove it please sync and then add it back and sync again.
@SilviaFitbit So I've used it this morning and still doesn't show my distance. I don't know why it did once and now not again? I have attached 2 photos from my bootcamp to show youScreenshot_20190427-092652_Fitbit.jpg
